Microwave was off and started running on it's own. Display indicates F6 when running. No functions are working and I need to unplug it to stop running. Should we bother with repairing?
The F6 is a relay failure which is part of the control board ( AP3177273) an easy enough part to replace. Not the least expensive part in the unit, but it is repairable if that is the direction you want to go.
