clavin29
#1 Posted : Wednesday, February 29, 2012 2:53:13 PM(UTC)
clavin29
i bought this used, knowing something was wrong with it. i was going to start diagnosing, so i hooked up, put on "rinse/spin" and turned on. drum moved a little and i can hear pump running. but thats it. its stuck there. i try and cancel or unplug, stays doing same thing. hit cancel twice and power, pump stays running. any suggestions what to do next? thanks
sidfink43
#2 Posted : Friday, March 2, 2012 4:57:46 PM(UTC)
sidfink43
Hard to say, look under the top and see if it has tech notes that will tell you how to put it into a diagnosis mode and will tell you how to do some testing on components like the control unit.
