3 Pages<123>
sabresfan
#11 Posted : Wednesday, February 29, 2012 9:30:38 AM(UTC)
sabresfan
Is it safe to assume the sensor sends a reading to the CCU? If so, can I unplug the TH2 plug from the ccu and take a reading from the unplugged (still plugged in at the sensor) wires to see if the data is "making it to" the ccu from the sensor?
Does that make sense?
Joe / APP Team
#12 Posted : Wednesday, February 29, 2012 10:11:38 AM(UTC)
Joe / APP Team
Sabrefan, Very good, you're on top of it. I thought I had mentioned that in my post, but I guess I forgot it.
You'll need some "pin point" meter probes or a couple of large paper clips to do the test at the TH2 connector, but you'll do fine.
sabresfan
#13 Posted : Wednesday, February 29, 2012 10:15:49 AM(UTC)
sabresfan
Makes sense. I am going to assume the "contacts" are recessed too far to standard MM probes? So just so I have it straight....I should disconnect the TH2 connection from the CCU. fashion some paperclips to stick in there and test using the MM. I should see the same reading there as I should at the sensor itself. If not, the reading is getting lost somewhere between the sensor and the CCU. Does that sound right?
Thanks for all the help!
Joe / APP Team
#14 Posted : Wednesday, February 29, 2012 11:02:49 AM(UTC)
Joe / APP Team
Sabrefan,
You have it exactly right, Great job.
:D :D :D
twarnock
#15 Posted : Thursday, May 10, 2012 6:14:23 AM(UTC)
twarnock
Did you ever resolve this? I'm got another post about the same thing - replaced the sensor, heater relay and now the CCU and still getting an F05. (Heater element tests fine at 15ohms.) I'm at a loss!
Joe / APP Team
#16 Posted : Thursday, May 10, 2012 10:04:57 AM(UTC)
Joe / APP Team
Twarnock,
You'll need to perform the resistance checks the the thermistor at the CCU, using paper clips and a multi meter, like the last APP post to Sabresfan. You've coverred everything except the harness and the plug connector pins in the connector.
Good Luck and Thanks
twarnock
#17 Posted : Thursday, May 10, 2012 10:11:42 AM(UTC)
twarnock
Thanks. I just posted an update/resolution to my original post in this forum. It turns out it was the wiring harness between the temp sensor and the CCU - one of the black wires was open. Ran a replacement wire and all is well! Thanks!
Joe / APP Team
#18 Posted : Thursday, May 10, 2012 11:11:41 AM(UTC)
Joe / APP Team
Twarnock,
Great, We're glad for you. So you're up and running and all is good.
Thanks for the update, we appreciate it.
bubver
#19 Posted : Tuesday, August 19, 2014 9:33:02 PM(UTC)
bubver
I am having same problem and curious how you found that it was the wire. I don't know how to test that to find out if it is my problem. I checked the water temp sensor and found that it reads about 9ohms at room temp, but don't know how to find out if it is a wire, heater, relay or what??? I am a novice. If you can direct me, please help. thanks!
bubver
#20 Posted : Tuesday, August 19, 2014 10:13:17 PM(UTC)
bubver
Having same problem, f05 code after 2-3 minutes and only hot water regardless of setting. Can you tell me how to perform resistance checks on wire harness at ccu, heater element and heat relay? I have tested water temp sensor and it tests fine... but I am a novice and do not know how to check the other things. Thanks
3 Pages<123>
