charlesb
#1 Posted : Wednesday, November 21, 2007 11:35:05 AM(UTC)
charlesb
Hi, I currently have no water being dispensed from my door. I have replaced the filter, no water filled the new filter. I replaced the water filter base, the filter then filled with water, but still no water is dispensed from the door. I don't think that it is a frozen line in the door; I let the unit off for 24 hours.
Any help would be much appreciated.
Charles
jdappl07
#2 Posted : Saturday, November 24, 2007 7:33:07 AM(UTC)
jdappl07
there is a coupler under the freezer door behind the kick plate disconnect that and have a little bucket or bowl hold the hose comes from the back in the bucket and try to get water if not water comes out into the bucket you nee a water valve if there is then it is in the door and you have to replace door on a frigidaire ref what is the serial number
charlesb
#3 Posted : Saturday, November 24, 2007 6:28:06 PM(UTC)
charlesb
Thanks for the reply, I thought that the valve may be the cause. I uncoupled the water line behind the kick plate, there was no water. I've already ordered the water valve.
Thanks again,
