sheila30083
#1 Posted : Friday, November 23, 2007 9:59:02 PM(UTC)
sheila30083
I placed my clothes in the dryer and went back to get them they were not dry and the dryer was still running with no heat.
abbie
#2 Posted : Saturday, November 24, 2007 5:51:10 PM(UTC)
abbie
the first thing to check is the fuses or breakers to make sure there,s 240 volts going to the dryer..
sheila30083
#3 Posted : Sunday, November 25, 2007 4:53:06 AM(UTC)
sheila30083
;) The dy doesn't stop and there no heat
abbie
#4 Posted : Sunday, November 25, 2007 6:50:01 AM(UTC)
abbie
sounds like a fuse or breaker there are two fuses or breakers .One will run the motor the other one the heat , if this dryer is not an appartment size dryer[small unit] then check both fuses/breakers..
