EAO
#1 Posted : Tuesday, November 11, 2008 9:30:52 PM(UTC)
EAO
I need to replace my ice/water dispenser actuator switch,
AP2584317 in my Frigidaire FRS26ZSEB3. Do I access the switch from the from the door front or the back?
#2 Posted : Wednesday, November 12, 2008 3:47:15 PM(UTC)
There is no access from the door liner. All repairs must be done from the front by removing the front cover first.
Here are the break down diagrams for the Frigidaire refrigerator Model FRS26ZSEB3
EAO
#3 Posted : Wednesday, November 12, 2008 7:12:22 PM(UTC)
EAO
Thank you. Wish me luck.
#4 Posted : Wednesday, November 12, 2008 7:21:09 PM(UTC)
Good luck and keep us posted.
skier2188
#5 Posted : Friday, July 1, 2011 10:16:07 AM(UTC)
skier2188
actuator switch is brocken off inside the door, so based on the instructions I need to remove the whole front door Ice/Water unit to do the repair, based on you experence is this a difficult job and should i have a professional do the repair???
youngna
#6 Posted : Thursday, December 29, 2011 11:06:14 AM(UTC)
youngna
Wondering if you were successful in this adventure? I have the same issue. Thanks.
Nothandy2000
#7 Posted : Sunday, February 26, 2012 8:06:26 PM(UTC)
Nothandy2000
I did it based on the instructions below. It took a couple hours as I had no idea what I was doing and was afraid I was going to break something. First, pulling the trip tray out takes a pretty good pull to get it off. No worries it will not break. Other things: I did not pull out the ribbon as it seemed like it would break and I read about people having trouble with the it after plugging it back in. I held everything in one hand and worked with the other (which is why it took so long). ANyway I also had trouble pulling the water hose off and then signficant trouble putting it back in (still not sure it is fully back in but it works). i tried forever to put the actuator in without removing the hose put in the end I had to in order to pull the whole unit out . Good luck to all who need to do this. Next time the bloke that broke it is going to fix it (hope its not me).
Two gain access to the control area you will need to pull
the drip tray out first.
With the drip tray removed, remove the 3 screws at the
bottom of the front panel.
Lift up on the front panel, there are tabs on the top of
the panel that slide into holes in the door panel.
All models with a touch selection on the front will have
a electronic control behind the front panel of the
dispenser.
Swing panel out to side, being careful not to pull the
wires out of the disconnect plug or the board itself.
Carefully unplug the wiring harness from the touch panel
on the front cover. This will give you
access to the control board.
On models with no selector on the front panel, when
you remove the front you can gain access directly to
dispenser because you do not have a touch pad or
board on dispenser
On models with electronic control to gain access to the
control, snap the light socket loose and remove the 6
small screws from the board.
Pull board straight out of housing. Disconnect plug on
left side of board. Disconnect 4 wires to dispenser
actuator switches.
With the board removed, remove the 3 screws from the
dispenser housing and pull the dispenser forward.
Remove water line from dispenser housing by pulling
straight out.
With the water line removed, the upper part of the
dispenser is free of the freezer door panel. The main
housing is part of the door panel, and is not removable.
The ice door and actuator switches, as well as the return
springs, can be serviced with the control module
removed.
Tension is held against both the water and ice actuator
by a stainless steel, two bladed spring mounted behind
the actuator switches. The spring is held in place with 2
screws.
The Actuators are held in place by stainless clamps at
each end of the actuator and the two bladed spring in
the middle. The actuators can be removed
by removing the 4 screws and lifting the paddle / ice
chute out of the housing.
On models that only dispense water and ice cubes the
dispenser will come apart the same way as models
with a control board. The difference is there is no light
in the housing and the wiring to the actuator switches is
connected directly the plug in the door wiring harness.
