Don Phillips
#1 Posted : Wednesday, February 22, 2012 10:46:15 AM(UTC)
Don Phillips
Twice now when we used the ice maker water continued to flow after we released the dispenser lever flooding the freezer and the kitchen. If iturn off the water to the unit for a bit when I re open the water it works O K for about a week then floods again. Iv'e been told its either the inlet water valve or I need a whole new ice maker, any ideas how to determine whats going on? Thanks for any ideas.
#2 Posted : Wednesday, February 22, 2012 4:25:52 PM(UTC)
Hi Don,
I'm afraid I did not get clear if the problem is with the ice maker or the water dispenser?
Ice maker is the device located inside the freezer which producing ice cubes.
The water dispenser, as well as the ice dispenser, located on the freezer door and used for drinking water.
Here are the breakdown diagrams and Replacement parts for General Electric PSS23MGTCWW Refrigerator | AppliancePartsPros.com
Don Phillips
#3 Posted : Friday, February 24, 2012 1:53:17 PM(UTC)
Don Phillips
Gene thanks for your reply and to answer your question it has happened only twice, both times when we dispensed ice
#4 Posted : Friday, February 24, 2012 3:03:54 PM(UTC)
So while you were tried to dispense ice, water was coming out from the water dispenser?
