markb
#1 Posted : Thursday, March 5, 2009 4:00:20 AM(UTC)
markb
I have replaced the door lock/switch assembly and I still get a "dr' code upon starting washer up. Any ideas?
Lesthanzero
#2 Posted : Monday, July 13, 2009 6:15:32 AM(UTC)
Lesthanzero
Only I have Frigidaire model # LTF6700FS0. I replaced the door lock/switch, did one load of laundry OK, now I'm getting the same problem again.
#3 Posted : Monday, July 13, 2009 4:49:21 PM(UTC)
Hopefully the Service manual will help you.
Post the results and we'll help you to find the correct part number if needed.
gcflyer
#4 Posted : Sunday, July 31, 2011 12:54:23 PM(UTC)
gcflyer
Hi I am having the same problem. I tried to jump the door latch switch, but still got the error "dr" with beeping. Research so far has told me that it may be the control panel. Can you give some input on that? Also, would love to have access to the repair manual if possible.
Glenn
#5 Posted : Tuesday, August 2, 2011 2:41:53 PM(UTC)
Glenn,
What is the complete model number of the washer?
jammerone34
#6 Posted : Wednesday, December 21, 2011 2:10:08 PM(UTC)
jammerone34
the problem i am having is with the ltf6700fs0 and it is when it starts to drain the humming sound is louder than what it used to be i was wondering if you could send me a pdf of the repair manual so i could see how to get to the pump and check the filter as well as the pump if needed.. my email is jammerone32@yahoo.com or if you want to contact me by phone im at 706-419-3839 thx....
ApplianceJunk
#7 Posted : Wednesday, December 21, 2011 3:00:17 PM(UTC)
ApplianceJunk
Emailed pdf service manual.
