Did you install the OEM magnetron or an after market part?
Double check all wire connections in accordance with the wiring diagram.
Gene OEM MAG # WB27X1OO17
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ...Double check all wire connections in accordance with the wiring diagram... Did you do it? Gene.
Gene Yes I Installed a OEM Magnatron part # WBX27X10017, and checked all wire connections Found all to be correct. Ran for 1 min. could hear it load up and fan slow down. Shut off Immeditly, Have Heat but noticed that mag very hot to touch, BAD Mag ??
Originally Posted by: matned ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ...noticed that mag very hot to touch... Check the cooling fan. Gene.
Gene Replaced Mag with another and all is well ( Part supplier replaced original at no cost ) Thank-you for your time. We will see how long my NEW Microwave will last this time. Matt
Gene Cooling fan operating Normal. Matt
I'm glad you were able to fix it.
Gene. This is very bad if you can not rely on a brand new parts.
