Hi Gene,
Thanks so much for all of your help. Have a great day and a wonderful weekend! :) :) :)
Best regards, KBrillon
cooktop duel element only goes to full heat
Most likely a shorted infinite switch, but I need a model number and any other information you can provide in order to get you going in the right direction.
I have an Amana cooktop that is exhibiting the same strange behavior. The left front will occasionally not turn off. It seems if we turn the knob off and on that will sometimes take care of it.
The model is AKT3040WW and the MANUF number is P1143730NWW.
Any help is appreciated.
Thanks!
Replace switch part number 12002422
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hi mine won't turn off and I swapped the switch and element from the other side but it still stays on
Rank: Guest
I have a 14 year old Frigidaire glass cook top stove that has been running perfect up until a couple weeks ago when I noticed a back burner wasn't turning off. The light indicator is on and the glass is quite warm to touch. The first time I noticed this I could get it to turn off by turning the know but the next time I was using the breaker. Can you tell me what part number I need for my old but loved stove? I hope I can still get the part I need. lol
Make: Frigidaire Model: PGLEF385E5
Thank you, Mel
