tyr67360
#1 Posted : Tuesday, March 3, 2009 3:53:42 PM(UTC)
tyr67360
Our washer timer only works intermittently on our favorite cycles. It seems to work consistently on the Delicate and Hand Wash. Do I need a new timer to fix this? If so, I have taken the part out and can not tell which part would fit since there are two listed and neither matches the numbers on the part pulled. The two part numbers I have are 22002188 and 22001693. I have seen a photo for the first part number listed that looks identical if that helps.
TechnicianBrian
#2 Posted : Tuesday, March 3, 2009 4:30:34 PM(UTC)
TechnicianBrian
There are different timers based on the serial number of your washer. Post the serial number and we can point you toward the correct part number for the timer you need.
tyr67360
#3 Posted : Tuesday, March 3, 2009 5:55:32 PM(UTC)
tyr67360
11148928qy
TechnicianBrian
#4 Posted : Tuesday, March 3, 2009 6:17:02 PM(UTC)
TechnicianBrian
This is the timer (AP4026364) for your model and serial number.
