rrab449@yahoo.com
#1 Posted : Friday, February 17, 2012 1:18:42 PM(UTC)
rrab449@yahoo.com
When you close the dishwasher door and press START, the dishwasher appears to be dead. I test the voltage at the swith intrerlock and voltage is good. I tested the voltage on the control panel and I get good voltage there as well. I would expect to see one or more LEDs lit when I push START even if there were something wrong elsewhere in the dishwasher.
Is the control board bad?
Simon / APP Team
#2 Posted : Friday, February 17, 2012 3:33:40 PM(UTC)
Simon / APP Team
Groups: APP Team
Most likely the problem is with switch.Very small possibility it is control board. Start with replacing the switch. If that is not a problem then replace the control board. Remember - you can return parts that you don"t need.
The switch Part number: AP5323726
