DECALGUY
#1 Posted : Monday, July 30, 2007 4:33:18 PM(UTC)
DECALGUY
Dryer runs continously on automatic permanent press cycle, does not shut off when the clothes are dry. It does shut off on timed cycle though.
#2 Posted : Monday, July 30, 2007 11:25:09 PM(UTC)
DECALGUY
Does the timer advance on the automatic cycle or it stays at the same point? Does it stop if you move the timer knob to the "off" position manually?
DECALGUY
#3 Posted : Friday, August 3, 2007 6:11:21 PM(UTC)
DECALGUY
It does stop if you move the knob to the off position manually. I don't know if the knob advances on the automatic cycle.
#4 Posted : Saturday, August 4, 2007 6:28:19 PM(UTC)
DECALGUY
Most likely the problem is a bad timer. It's not repairable and has to be replaced.
For the future references here are break down diagrams for the GE dryer Model DBXR453ET5WW
Good luck.
