tammyneedshelp
#1 Posted : Sunday, March 1, 2009 1:28:36 PM(UTC)
tammyneedshelp
under the door of the dishwasher water leaks on and off. Some times it does and sometimes it doesn't. Need to know if that is the gasket that is bad or if there is something else there that I don't see in the diagram.
#2 Posted : Monday, March 2, 2009 3:55:31 AM(UTC)
Model PLD2850RDC2
Check out:
Item 3 in the "Tub" section. Actual part is at the bottom of the list F3
Item 49 in the "Door" section
Check that the gaskets are pliable and do not have any nicks etc.
Also clean them.
If unsure where it is leaking from remove the kick plate and check under the unit.
Sometimes the fill float (front left hand side) get cruddy up and can leak intermittently
Here is a good link from TechnicianBrian
<title>Frigidaire Dishwasher Leaking from the Door
LG LDF7774ST leaking dishwasher (Dishwasher Repair)
by corvets 4/25/2020 5:12:21 AM(UTC)
Leaking Dishwasher (Dishwasher Repair)
by theflanigans 9/2/2015 6:42:39 AM(UTC)
Non-Handy Woman + Leaking Dishwasher = DISASTER (Dishwasher Repair)
by cbrennan 10/12/2013 5:24:02 PM(UTC)
Leaking Dishwasher (diverter motor) (Dishwasher Repair)
by rmsmith 4/19/2012 7:18:44 AM(UTC)
by mljoecks 10/15/2011 9:14:30 AM(UTC)
by clints 8/27/2010 11:44:16 AM(UTC)
by pdl 3/10/2010 5:06:33 PM(UTC)
by macnlrc 11/9/2009 4:49:54 PM(UTC)
Leaking dishwasher (Dishwasher Repair)
by Brucefamily 9/3/2009 2:22:34 PM(UTC)
by EMHBARMAN 2/29/2008 2:31:42 PM(UTC)
by dcooker85 2/18/2008 1:57:20 PM(UTC)
by warrenjr 12/3/2007 4:34:05 AM(UTC)
by verne k 11/6/2007 6:25:42 AM(UTC)
Leaking dishwasher door (Dishwasher Repair)
by flowboard 9/21/2007 11:14:46 AM(UTC)
