pat odea
#1 Posted : Wednesday, February 15, 2012 5:57:12 AM(UTC)
pat odea
my may tag washer is shaking very badly while in spin cycle do i need a herring ,how do i fix problem,the machine is level thanks pat
Gary/APP Team
#2 Posted : Tuesday, March 6, 2012 10:53:49 AM(UTC)
mattt
Groups:
Hello . Everything points to the balance ring Part number: AP4340045
sometimes these will get a hole in them and loose the filling that balances the tub, more than likely this is your problem ,I would check this, Thank you and good luck !
washer shaking while spinning (Washer Repair)
by anneanne 10/12/2010 11:02:14 AM(UTC)
