Rick442
#1 Posted : Monday, February 13, 2012 5:14:04 AM(UTC)
Rick442
My washer last night just gave up the ghost. It began making a loud noise after it broke apparently during spin or just after because the clothes were relatively damp not dripping wet. Now, it won't agitate or spin at all it just has the clanging. I changed the clutch assembly out a few months ago for spin cycle problems. Is this the end game noise for the washer??? :(
sidfink43
#2 Posted : Tuesday, February 14, 2012 5:07:57 PM(UTC)
sidfink43
It could be the transmission, but the first thing to check is the coupling. Over 95% of the time that is the problem, particularly if it will drain.
Rick442
#3 Posted : Tuesday, February 14, 2012 6:05:40 PM(UTC)
Rick442
It drains but the same sound occurs during the process, loud noise as the pump's being turned, it's not pretty.
sidfink43
#4 Posted : Wednesday, February 15, 2012 4:26:37 AM(UTC)
sidfink43
Okay, that means the motor is turning so it would seem the coupling is the likely culprit.
Guest (4)
