how do I unfasten the motherboard?
Use small pliers and sweeze the nylon pins, then pull off the board.
Originally Posted by: richappy  Use small pliers and sweeze the nylon pins, then pull off the board. Thanks.Wish everythig was that simple.Now I can have a look at the relay soldered links.
