my washer will not spin acts like it has to much water in it just spins weakly
Sounds like the clutch is bad
Don't think there is a clutch in this. Either you have a hole in the tub making the bearings wet, or you have a bad pump.
Originally Posted by: allen9258  Sounds like the clutch is bad none of the digrams show a clutch or brake shows a stator that is it
