scmitch10
#1 Posted : Sunday, February 12, 2012 11:31:03 AM(UTC)
scmitch10
My owner's maual states if my dryer is not heating but the tumbler is, I should replace one of the 2 fuses. I check the schematics of the dryer I own but can only find one fuse by the power cord which connects to a fuse internally. I need to know where the other fuse is located because the fuse i took off is not the one that makes the heat work. I need to know where the other fuse is located. It doesn't show 2 fuses in the schematics anywhere just the one by the power cord. Thanks
#2 Posted : Monday, February 13, 2012 2:08:24 AM(UTC)
Replacement parts for Frigidaire FEQ1442ES0 Frigidaire/dryer | AppliancePartsPros.com
Here is the tech sheet that comes up for this unit. Just to be sure we are both looking at the same thing.
http://manuals.frigidaire.com/p...ebster/134509400efsa.pdf
If the tech sheety I have is correct then this unit does not have a thermal fuse in the heater circuit. The fuse you mention will kill power to the motor.
I think they may be referring to the fuses Or a circuit breaker in the house electrical panel so I would check the power to the unit first.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
The heating element requires the full 240 volts while the motor and control board runs off of half the line (120 volts).
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
If power is OK check the high limit thermostat (Item 33 in Section 1).
It should be 0 ohms.
If OK check the heating element
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case.
IF OK check the thermistor, should be around 50,000 ohms at room temperature.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
scmitch10
#3 Posted : Monday, February 13, 2012 7:46:45 AM(UTC)
scmitch10
Thaks for your help.
