I have recently cleaned out my drain pump, it was clogged. When I tried to run it to see if I fixed the problem it acted funny. I hit the power button and when I go to hit start it shuts off. I had water spray out of the drain hose when I removed it and I am not sure if that would hurt anything. Also I have unplugged it for an hour and it didn't help. Please help me figure this out.:confused:
There should be tech notes under the top panel or inside the lower service panel which will tell you how to do some diagnosis. Focus on the main control board, that seems likely to be your problem.
