Tmarinalongo
#1 Posted : Saturday, February 11, 2012 10:12:16 AM(UTC)
Tmarinalongo
Wash cycle will not will not advance and stays in a constant water fill status. Uncertain if it is the valve or the timer. Also, the wash drum wobbles.
sidfink43
#2 Posted : Sunday, February 12, 2012 4:32:50 PM(UTC)
sidfink43
If the water will stop filling when the machine is turned off, open up the console and take off the tube connected to the water level switch and blow it out.
If that does not fix things then try replacing the water level switch. If it will not stop even when the machine is off then the water valve assembly is likely the problem.
Your wobble problem may be a broken support structure or bad springs.
Kenmore top load washing machine (Washer Repair)
by 12leslie 12/31/2007 8:24:21 AM(UTC)
