This machine is leaking water. Drain hoses from drum,pump,inside and out are all dry. Seems to be coming from the area of the water inlet valve. Any suggestions? Supply lines from wall to inlet valve are also dry. Inlet hose does not appear to have a leak under a pressure test.
Run dishwasher and determine where the water is coming from.
