We just replaced the icemaker and water valve and it is working great however it is not dispensing ice, the water dispenser works fine. So I need to know what exact part I need to fix this on the ice dispenser please :)
Gene- It does not make any noise and I don't believe the chute opens, nothing happens. Any ideas? Thank you :)
Remove the dispenser cover (the instructions are attached) and inspect all parts inside. Post the results. Gene.
