trina1976
#1 Posted : Monday, February 6, 2012 1:40:16 PM(UTC)
trina1976
I washed a blanket and it fell apart in the machine now my washer is not draining. We have tried to clean the inside and outside hose and the drain and got the remaining water out of it but it still is not draining. I wondering if there is a trap for lint inside the machine somewhere. If so could you please tell me where it is located and how to clean it. If there is anymore tips please let me know, can't afford someone to fix it and would like to try it myself first.:(
#2 Posted : Monday, February 6, 2012 5:20:30 PM(UTC)
Remove the drain pump and sump hose (#41 on the diagram). Disassemble the drain pump and check for any foreign objects inside the pump and hose. The instructions are attached.
Here are the breakdown diagrams and Replacement parts for Frigidaire ATF6700FS2 WASHER | AppliancePartsPros.com
File Attachment(s):
trina1976
#3 Posted : Tuesday, February 7, 2012 6:13:18 AM(UTC)
trina1976
Thanks so much and we did fix it. We took off the hose took the filter out and clean it, now it working :))
#4 Posted : Tuesday, February 7, 2012 1:08:44 PM(UTC)
You are welcome. I'm glad it's up and running.
