I am installing new balance link and need help with the path of the string. If I run it through the pulley once it seems like the string & spring combination is too long. (I am reusing the existing spring.) Unfortunately both sides need replacing so I don't have an example to work from. Thanks
Brian, Thanks for the info. I do have the string running through the pulleys correctly, but if I just make the "S" through the pulleys the string seems too long. I have tried putting the spring in the furthest back position but it doesn't seem to get tension until the door is fully open...Any suggestions?? Thanks.
Groups: Expert
the spring doesnt hook on the place where you think it would, it hooks on to the round hole past the area where normally they would hook, it for stainless steel doors.
Like beentheragain said, the spring connects to the frame upright at the rear of the tub behind the rear roller. There should be some tension when connected, but not much.
That solved my issue. Thanks for the help.
