YAHOO21
#1 Posted : 17 years ago
YAHOO21
Kenmore Laundry Center - Is the drain hose from the tub to the pump replaceable?
I am baffled at this point as to how to remove it from tub.
Thank You :confused:
okbobcats
#2 Posted : 17 years ago
okbobcats
remove two clamps and hose that goes to pressure switch.
YAHOO21
#3 Posted : 17 years ago
YAHOO21
There is only one clamp on this hose at the pump.
Maybe there's a nut and washer/ gasket on the hose inside the tub?
