ottmeister
#1 Posted : Saturday, February 4, 2012 9:49:18 AM(UTC)
ottmeister
The electric heating elements in the dual size burner will usually cycle on and off to maintain the correct cooking temp. Once in awhile the elements do not shut off and the burner stays on until we use the knob to turn the burner off. What part(s) are likely the cause and should be replaced?
#2 Posted : Saturday, February 4, 2012 7:00:26 PM(UTC)
All such heating elements have a limiters as a part of the element. These limiters don't sell separate, so you have to order the whole heating element.
I'm assuming you meant the left side dual burner.
- The dual element assembly Part number: AP2027788
ottmeister
#3 Posted : Wednesday, February 8, 2012 1:29:27 PM(UTC)
ottmeister
Thanks for the reply Gene. The burner with the problem is the one on the front right of the cooktop. It is round but has two sizes, both concentric circles. There is a switch that lets you choose the smaller inner circle or both the inner and larger outer circle. Can you provide a link to this part? Thanks.
ottmeister
#4 Posted : Saturday, February 18, 2012 8:06:10 AM(UTC)
ottmeister
Hey Gene, can you provide the correct part number for the front right burner for this stove?
