mtgking1
#1 Posted : Thursday, February 26, 2009 4:03:48 PM(UTC)
mtgking1
Hi All:
Our Kenmore Dishwasher started acting up lately. The "Cycles" buttons weren't recognizing our commands. If we pushed "smart wash" it would sometimes light up, sometimes not. Same for all the other Cycles buttons.
The Options buttons would light and recognize commands, but now the Cycles buttons don't work at all, and the "rinse aid" button stays lit. The Options buttons still work.
I saw another post on here that was similar, and I switched out the "brains"/control panel, but it still does the same thing.
Any suggestions??? Thanks so much for any help!!
#2 Posted : Friday, February 27, 2009 4:12:57 AM(UTC)
Here is a tech sheet
https://www.servicematters.com/d...0Sheet%20-%208537797.pdf
It does have a method on how to check the keypad with a meter
mtgking1
#3 Posted : Friday, February 27, 2009 5:22:15 PM(UTC)
mtgking1
Thanks for the help. Not real sure I quite understand the tech stuff very well, but will give it a shot! Thanks so much.
#4 Posted : Saturday, February 28, 2009 1:19:46 AM(UTC)
Just take your time, testing the keyboard it is not difficult.
In case you do not have a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
