mrmsu
#1 Posted : Monday, January 30, 2012 7:44:28 AM(UTC)
mrmsu
-Edit- I posted in the thread topic that the faults only happen after 45 minutes of cooking time. This is not the case as confirmed by my wife. The faults happen anytime...sometimes immediately and other times not at all.
I have been getting F2 and F3 fault codes with my oven. I came to this forum, read up and found that the temp sensor may be bad so I ordered another one from Appliance Parts Pro and installed it. Everything seemed to work fine for a day or so but now the error codes are back. F2, F3, and F5.
I've checked the wiring, touched all the connectors, looked for obvious items but I can't see anything out of place. I'm at the point of replacing the ERC but I dont't want to do that unless there is a reason. I'd appreciate any help.
Thanks!
#2 Posted : Friday, February 3, 2012 3:25:50 PM(UTC)
Most likely the problem is a bad ERC, especially if there are so many different error codes shown up. There is one letter missing in the model number you posted. I'm assuming the missing letter is "J" and the ERC
Part number: AP2633034
You also have to order the new clock plate because it's glued on.
- The clock plate Part number: AP2025222
You can find the complete instructions on how to install the new ERC in one of our previous threads http://forum.appliancepartspros...ops/6450-wb27t10190.html. The information was provided by one of our members BamaCracker.
