Originally Posted by: Troubleshooter  About 6 weeks ago, my fridge stopped getting cold (freezer working fine, though). I checked the coils, which were completely iced over, and defrosted them with a hair dryer. On the advice of someone who knows a bit about appliance repair, I REPLACED the MAIN BOARD and the DEFROST HEATER. Everything worked great until a few days ago, when the same problem occurred -- the fridge was no longer cooling, but the freezer worked fine. I checked the coils, which were iced over again. This time I used a hair dryer and hot water to de-ice them. I put everything back together in the early morning and all seemed well until evening, when the fridge temp started rising again (I had hung a thermometer inside); THIS TIME, however, EVEN THE FREEZER HAD STOPPED WORKING! I could feel warmth coming from the back panel (no “hot smell” or overheating, just a “warm-glow” warmth when I touched the back panel). After unplugging the fridge and removing the back panel, I checked the defrost heater, and it was slightly warm, so I'm assuming that's where the warmth came from. A couple of questions: 1) Is it possible the main board has gone out (again), since the FAN and COMPRESSOR are NOT RUNNING when the fridge is plugged in? Could something have caused it to short? 2) I read that if it's not the defrost heater, it's probably the TIMER or the THERMOSTAT. (I don't think my model has a timer.) Could a FAULTY THERMOSTAT CAUSE THE NEW MAIN BOARD TO SHORT OUT? 3) If it's the THERMOSTAT, then I'd like some ADVICE ON HOW TO CHANGE IT. I located the thermostat, which has two wires, one pink and one orange. The pink wire is attached to a white, plastic "slip," which fits into a hole connected to the defrost heater. The orange wire leads into a hard, black plastic "wrapping," then continues on to a round, blue casing attached to the back of the fridge. My question is, COULD THE THERMOSTAT BE CAUSING THE PROBLEM, and, if so, HOW DO I REMOVE THE ORANGE WIRE? Does it disconnect at the point of the black, plastic wrapping or at the back of the fridge, where it goes into the round blue casing? Thanks for any advice you may have. You could very well have a bad board, since the compressor and the fan is not running. Lay your hand on the top of the compressor, and see if the compressor is hot, if so, the fan motor could be bad. If the compressor is running and the motor is not, then that would mean the condensor motor is bad. Or, the overload and relay combination mounted on the compressor is bad. If the compressor is cold as a cucumber, I would get another board. Tom ApplianceEducator.com
