help please , my side by side frig door makes a loud pop when the door reaches the half open position in both opening & closing process, what do I need to replace. thanks Dave
Here are your parts Model FRS6L9EFSS0Take a look at Item 22 In Section 1, could be this is broken or cracked. Also check the corresponding hinge pin on the door itself. |
THIS FORUM IS DEAD!!!!!!! |
