bkcprice1
#1 Posted : 16 years ago
bkcprice1
Okay here's my problem(s)
First the timer stopped moving in the Auto Dry Cycle, it would just run forever. So I started using the timed Cycle instead.
Then it stopped drying. The heater would only turn on now and then and then only for a short while.
I replaced the Thermal cut off kit, which includes both thermostats.
This didn't help but I did notice that the igniter would turn on and off but the burner didn't light.
So I replaced the Flame Sensor and both Solenoid Coils.
IT WORKED...for one load!
Now the igniter doesn't even turn on. So now what do I do?
By the way I have checked and cleaned out the vent.
kayakcrzy
#2 Posted : 16 years ago
kayakcrzy
There is a thermal fuse in the back of the dryer. Take the back off, and you will see the thermal fuse. It is white in color, and is a 1/2 wide, and an inch and a half long. That would stop the ignitor from coming on. Tom ApplianceEducator.com
bkcprice1
#3 Posted : 16 years ago
bkcprice1
Tom,
Thanks, do you know if I can check it with a multimeter and how to see if its okay or is it a either it works or it doesn't type item? Bob
kayakcrzy
#4 Posted : 16 years ago
kayakcrzy
Yes Bob, take the 2 wires off of the thermal fuse, and of course the dryer is unplug when we do this, and then check the thermal fuse on ohms to see if you get a reading. If no reading it is bad. Tom ApplianceEducator.com
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 about a year ago
Whirlpool Gas Dryer Not Drying Clothes correctly (Dryer Repair)
by ts_peach 14 years ago
Kenmore Elite HE3 Gas Dryer not drying (Dryer Repair)
by TKerscher 16 years ago
Maytag gas dryer not drying (Dryer Repair)
by scott805 16 years ago
Gas Dryer not drying during run cycles (Dryer Repair)
by GMP 18 years ago
