rickfry1
#1 Posted : Saturday, January 28, 2012 6:24:05 AM(UTC)
rickfry1
the machine has been stopping at the rinse cycle. if i turn the timer eventually it will continue on. then i start another load and it may stop at differant times,wash or spin cycles. i have jumpered the lid switch it operates the same. i spin the timer and it will start but will not finnish the load.do you think its the timer
sidfink43
#2 Posted : Monday, January 30, 2012 4:47:33 PM(UTC)
sidfink43
Since it will run when you move the timer, it seems like the timer is the issue. Replace it and see if that fixes things.
