1vrbilly
#1 Posted : Tuesday, February 24, 2009 7:23:40 AM(UTC)
1vrbilly
Hello, I have a six burner thermador gps366s cooktop and some of the piezo igniters have come loose. They still work if I manually adjust them but since they are loose they just move again during cleaning. I have found the new igniter part on your web site but need some more info on installation.
What keeps the igniter attached?
Is there another part I need?
Does it install from the bottom?
Is there a good drawing or manual for this?
thanks, Billy
#2 Posted : Wednesday, February 25, 2009 3:43:30 PM(UTC)
Hi Billy,
[COLOR="Red"]What keeps the igniter attached?[/COLOR]
There is a mounting ring from the bottom of the burner base.
You have to order one of them for each igniter you are going to order. In order to replace the igniter you have to remove the burner base.
Thermador keeps all repair manuals as a top secret.
1vrbilly
#3 Posted : Thursday, February 26, 2009 4:58:44 AM(UTC)
1vrbilly
Hello Gene,
thanks for the response. I will try to find these rings in the parts list but it is not very clear from the exploded view drawing. I assume that they are some type of spring clip and I guess I will just learn my way thru dis-assembly.
If you have any tips on the sequence of getting the burner base pan out it would be much appreciated.
thanks for your help,
Richard
nptuthlax
#4 Posted : Thursday, February 26, 2009 5:47:57 AM(UTC)
nptuthlax
Originally Posted by: 1vrbilly Go to Quoted Post
Hello Gene,
Richard
I have a Thermadore Gas Cooktop model PCG364 and I'm need help to replace the Spark ignitor. I believe I have to remove the Burner Ring and I'm trying to find a tool to remove the ring. 1st am I correct that I have to remove the burner ring? and 2nd can you tell me the tool the will allow me to do this?
nptuthlax
#5 Posted : Thursday, February 26, 2009 5:48:35 AM(UTC)
nptuthlax
Hello Gene,
Richard
#6 Posted : Thursday, February 26, 2009 2:55:51 PM(UTC)
Richard,
The mounting ring is shown as #61 on the diagram.
In order to remove the burner base (#59) you have to unscrew the venturi (#58). Use WD-40 to loose it easier.
#7 Posted : Thursday, February 26, 2009 2:57:56 PM(UTC)
nptuthlax ,
The model number you posted does not come up.
Verify and repost it.
nptuthlax
#8 Posted : Friday, February 27, 2009 9:05:03 AM(UTC)
nptuthlax
Sorry, the correct model # is PCS364GLUS
#9 Posted : Friday, February 27, 2009 11:03:38 AM(UTC)
You can use the same instructions given to Richard. You would like to use a socket wrench in order to remove the venturi.
Here are the break down diagrams and the parts list for the Thermador cooktop Model PCS364GL
CharlyB
#10 Posted : Wednesday, September 7, 2011 8:33:46 AM(UTC)
CharlyB
Hello Gene,
I've a Thermador PCS364GLUS and I'am replacing the 4 igniters but i can´t find the part number for the wires that connects them to the control module
Can You help me please with this?
Thanks in advance
Guest (5)
