ace#2
#1 Posted : Friday, January 27, 2012 9:21:43 AM(UTC)
ace#2
Was using oven when it just went blank...checked outlet,,,ok...in a min or so, the panel lit back up, said enter T of D,which I did and started it again...went blank again..did this several times...I cleaned everything on it...pulled top louver panel, main control panel, checked fuse, ok...still blank....hit the top panel once...lights came on panel...tried it again...went blank again for good...have tried everything I know....what could cause this ?? main processor board ? or what ? any ideas ..I called a local service and they told me to buy a new one...not worth it to repair...it has worked great since I bought it about 4 yrs ago...would like to keep it if I can repair it...
Any ideas would be appreciated...
Acer#2
ApplianceJunk
#2 Posted : Friday, January 27, 2012 9:55:04 AM(UTC)
ApplianceJunk
Could be a bad solder connection on the control board.
