Petezr
#1 Posted : Wednesday, January 25, 2012 6:27:38 PM(UTC)
Petezr
My Maytag electric oven won't heat up correctly. I checked the element and it shows 23 ohms so that should be good. The broil element is also good. Voltage to the back of the oven is correct and voltage to the element is also correct. When I turn it on it takes a good hour to get to 200 and then about another 1/2 hour and tops out at 265. Thats as high as it will go.:mad:
What do i check next?:confused:
Petezr
#2 Posted : Friday, January 27, 2012 6:19:46 PM(UTC)
Petezr
BUMP:confused:
I need help, anybody?
Petezr
#3 Posted : Monday, January 30, 2012 2:50:16 PM(UTC)
Petezr
I'll try this again in the hope I get a response otherwise I probably will just start shopping for a new oven.
Anybody have any input?
5lilhawks
#4 Posted : Tuesday, January 31, 2012 9:42:14 AM(UTC)
5lilhawks
Mine did this last year and again saturday night, last time ther is a circuit breaker on back lower portion of oven where power cord goes in, round switch held on by two screws, push red button in center, if it clicks you have reset it, if it springs back it is not tripped, fixed my problem.
Maytag oven won't heat up (Oven Repair (including Ranges and Cooktops))
by steelerfan349 10/22/2010 2:42:24 AM(UTC)
