Several months ago, I noticed that it took way too long to cook a pizza, even though the oven said it was heated to the temperature I set. As time has gone on, the gap has widened between set temperature and actual temperature. I figured it was the element and figured I'd get one when I got around to it. My broiler, however, was working just fine -- until the other day. That, too, is not working correctly. It heats, but doesn't get red and won't cook a steak before you die of starvation. Both elements provide heat, but not like they're supposed to. Doesn't seem likely that both elements are "going", but what do I know. Any help would be great. :(
The first thing I would check is the circuit breakers for the oven. They both must be on.
your going to have to replace your probe and control board. the heat your are getting is in the preheat mode.
