MikeRaff
#1 Posted : Monday, January 23, 2012 1:06:37 PM(UTC)
MikeRaff
My maytag oven started displaying an F1 error code whenever I tried to set an oven temperature. I tested the temperature sensor as recommended in some of the forums and it was testing low, right around 800. I replaced that and now the error code has gone away but I'm not getting any heat when I try and turn on the oven. Any thoughts on what the problem might be? Is it even something worth fixing? Thanks in advance for any help you can provide.
#2 Posted : Monday, January 23, 2012 5:01:52 PM(UTC)
Most likely the problem is a bad clock/timer. Unfortunately this part is no longer available.
