cpinke15
#1 Posted : Tuesday, November 20, 2007 9:06:22 AM(UTC)
cpinke15
I need help! All of a sudden, my freezer will not stop running. I have checked the manual and none of their issues or fixes will fix my freezer. Does anyone know what I can do besides turning it off to get it to stop running?
Help! :confused: :( :mad:
kooler
#2 Posted : Wednesday, November 21, 2007 9:29:32 AM(UTC)
kooler
Place an accurate thermometer in the freezer to find out your temp... Ideal temp should be zero to minus 5 F... If your unit is running 20 below or less and adjusting the temp control warmer doesn't turn off the compressor then you may have a defective thermostat (AP2113836)... If your temp is above zero then you may have defrost or refrigerant charge issues...Post back...
Upright Freezer Help Needed (Refrigerator & Freezer Repair)
by Gerardp 10/12/2012 12:39:44 PM(UTC)
