I have replaced the bulbs, but the light over the range still does not work. Is there a fuse or a reset button somewhere? Everything else on the control panel works great!
Originally Posted by: gzitt  I have replaced the bulbs, but the light over the range still does not work. Is there a fuse or a reset button somewhere? Everything else on the control panel works great! I have the same problem. Thought the harness needed replacing but there is no power throug the light harness connector. Is it the fuse inside near the rt side top of unit?? Thanks
Be advised, the website this guy is promoting states that they will contact you with progress about the repair progress of your microwave display and that it should be shipped within a couple of weeks. That's a bald face lie. This guys cashs your check and then never gets back to you. Don't use his repair service.
