Hi, all. Please help: GE PROFILE ARCTICA 1.5 years old. Has been working until 1 week ago: The ice maker is not working: No water comes out into the ice maker, the green light is blinking. The water line is fine we can get water from the dispenser on front. I have remove all ice in the maker and cleaned it out, replaced the filter/rest. Pooled it out checked the line OK. Please advice. Thanks.
The blinking LED indicates a fault condition in the ice maker. The ice maker has to be replaced. - The part for the new ice maker AP3853272 Gene.
Thanks. Will check it out.
Hi, all. I ordered the ice maker which is on the transit. Can some one help me with some instructions/tips on how to replace the ice maker? There is no instructions come with it. Thanks.
Remove the ice bin. Remove two screws, holding the ice maker and unplug the power cord. Remove the ice maker. On the new ice maker install the water chute (plugs in) and install the new ice maker.
Thanks. got it worked on Wednesday. There was an instruction came with my order. Very simple. Only 1 screw to open, took 5 minutes. Got ice late on T-day. I have two of those so no big deal. It has been fully operating now. Thanks again.
I have the same problem (water is fine to the cup, no ice is being made and green light is blinking). However, my model number is PSS26PSTSS. Will this same part work for me?
russcarver, The blinking LED indicates a fault condition in the ice maker. The ice maker has to be replaced. - The part number for the new ice maker is AP4345120 Gene.
I have a similar problem but the green light next to the ice maker power switch is constantly on. No ice, no water flowing into the ice maker chamber, no sign of part moving. My GE Arctica model is PSS26SGRD SS.
Thank you!
I'm having the same problem. No light blinking, maker is still making ice. It appears the motor that pushes the ice in to the hooper is not functioning. Does anyone know if this is a part under warranty?
