On the panel across the top of my stove, the first number of the oven temperature does not light up. The others do. Everything else works. Can this be fixed or do I need a new panel and if so, what is it called and how do I get it? Thanks!
Here are your parts Replacement parts for RF362LXSQ models | AppliancePartsPros.comThe control board is Item 12 in section 2. It cannot be DIY repaired. Manufactures do not publish schematics of the boards so unless you can see a bad solder joint on the back of the board it must be replaced. There are companies out there that will repair control boards. |
THIS FORUM IS DEAD!!!!!!! |
