I have a front loading GE Washer that stopped filling on the wash stage. I can turn the timer past wash and when it hits rinse it fills fine. It makes no difference which temp setting or type of cycle that is chosen. Just won't fill up.
When this happens and the timer passes the fill stage it cycles and runs, just runs dry.
I am thinking it's the timer, any suggestions?
