Spin cycles (rinse/spin) cause out of balance shutdown even with small loads. repair service noted dampers appear need replacing. 2 questions: 1. sound like this could be the problem 2. how difficult are they to replace (e.g., special tools) -- it would appear that it may be simply a matter of loosing springs, taking off support rods, and drive belt to be able to raise tub/trasmission unit to slide in dampers
Thanks for any help
Gene, Just what I was looking for. Thank you. Jay
