The front panel will not light up. You can't start the dishwasher. I checked the breaker box and no breaker was thrown. What could be the problem?
Originally Posted by: dcds The front panel will not light up. You can't start the dishwasher. I checked the breaker box and no breaker was thrown. What could be the problem? Could it be a fuse?
As far as I can see this unit does not have a fuse.
Check that there is power to the unit with a meter.
Check that the wire nuts that connect power to it are OK.
If all OK then check that the door interlock switches are OK.
If OK then odds are the timer is shot, unfortunately it looks like it is no longer available. |
THIS FORUM IS DEAD!!!!!!! |
