I replaced the thermal fuse, it worked for two days and quit again, but it was still glowing red inside from the blower, should I replace the high limit tstat in addition to the thermal fuse?
I could not find any info on the given model number. Please check it Are you sure it is not MDE.
Also was the fuse you replaced on the blower or the heater assembly?
If it was on the blower the most common cause of it blowing is the vent system. Check/clean the vents system. Also make sure that the louvers on the exteriror vent open all the way. |
THIS FORUM IS DEAD!!!!!!! |
