dryer senses when clothes are wet, add minutes but then doesn't sense when dry to stop from running. Also what used to be aprox. 60 minutes of run time to dry the clothes has now turned into 150 minutes. The vent has been completely cleaned out and replaced with a new one just to be sure it is clean. I've been told that it could be the blower wheel. I just want to get another opionion and I want to know what function the blower wheel plays in a dryers functions? Corrected model number is WGD8300SW
The given model number comes up as a washer not a dryer. Please check it. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  The given model number comes up as a washer not a dryer. Please check it. whoops, it is WGD8300SW
I do not post on gas dryers. You may want to re-post with the correct model number and perhaps someone else with gas dryer experience will reply. |
