tcat1100
#1 Posted : Monday, February 23, 2009 5:02:04 AM(UTC)
tcat1100
70 series kenmore does not appear to be drying clothes enough when spinning.. Can someone send me detailed instructions on how to remove clutch pack assembly on this model?? I was told to try 'cleaning' surface with sand paper and 'lengthening" spring??? Thanks
#2 Posted : Monday, February 23, 2009 5:38:17 AM(UTC)
Go to www.applianceaid.com for info on this. Pull the tranny, remove the retaining clip and remove clutch. If a lot of oil on it from the tranny, you have a bad tranny.
If ok, remove the pad and spring from the clutch housing and add a few small washers to the spring retaining clip, should fix it as long as the spring is still retained.
tcat1100
#3 Posted : Tuesday, February 24, 2009 3:21:40 AM(UTC)
tcat1100
Could not locate instructions on taking clutch pack off?? Do i need special tools?? What actual link do i use?? Thanks
#4 Posted : Tuesday, February 24, 2009 3:36:54 AM(UTC)
There is a retaining C clip holding the clutch housing on, just dig it out and remove the clutch, or you can just leave it on the tranny and fix.
