waynes91
#1 Posted : Saturday, January 14, 2012 1:13:14 PM(UTC)
waynes91
got a front loader amana washer mod # nfw7200tw,does not go into the rinse cycle,after 19 min on timer,and the lite is lit for rinse on the display. you can hear a humming noise followed by some clicking noise, this will go on for a while, the 19 still remains showing during all this, after awhile it will flash nd on the display then i turn it off.. doesn't want to play no more:( yes the water does not drain either, i have unpluged the power for awhile seeing if the would reset something,nothing changed, im hoping for a simple fix, thanks
sidfink43
#2 Posted : Sunday, January 15, 2012 5:56:06 PM(UTC)
sidfink43
On the inside of the back panel there should be a tech sheet that will show you how to put it into test mode. Focus on the control unit and motor control unit.
waynes91
#3 Posted : Monday, January 16, 2012 1:51:32 AM(UTC)
waynes91
thanks, ill check it out after work
waynes91
#4 Posted : Tuesday, January 17, 2012 5:29:17 PM(UTC)
waynes91
ok found tech info book, seems things where look good but when diagnostic codes i got a few 1,10,15,22, now the whole thing dosnt work, b4 it would fill and wash, but then wouldnt drain, which the nd displayed which was water level problem, also too i notice the selector knob was really wobbly like, so i may just call in repair man,to see what the cost would be , if to much just get a new one (not a amanda) will need to look into a good brand if there is such a thing..
waynes91
#5 Posted : Monday, January 30, 2012 6:33:28 PM(UTC)
waynes91
well had the repair guy come over .. there was a quarter stuck in the pump:confused: got the p/n for a new pump easy to replace myself (one of the vanes on the pump was broken still works till i get the new one ,
