ncduckman
#1 Posted : Monday, February 23, 2009 5:05:50 PM(UTC)
ncduckman
First, I want to say thanks for such a great site!
I have a Frigidaire ES-100 gas range. It has been just fine until now. When I hit the broiler or oven button, the indicator/on light (next to the oven or broiler button) will flash for a few seconds then stop. If I remember correctly, when it worked, the indicator light will just stay lit. I am not getting any error codes.
I replaced the ignitor today to no avail. No change, still doesn't work. The ignitor does not get hot, nothing happens. The light just blinks for a few seconds then quits.
I appreciate any suggestions on where to look next, as I do not want to keep on replacing parts hoping it will work.
Thanks,
Robert
#2 Posted : Tuesday, February 24, 2009 7:11:17 PM(UTC)
Robert,
Remove the wires from the gas safety valve and check for continuity between the terminals. If there is no continuity then the gas safety valve has to be replaced.
If there is continuity then the control board (aka a clock) has gone bad.
- The part number for the gas safety valve is AP2131109
- The part number for the clock is AP3959387
Here are the break down diagrams for the Frigidaire range Model FGF337AWJ
